Mode |
Tool |
Tool set |
Modes for The Symbol Insertion tool |
Tubular Rivet
Fasteners |
Multiple rivet tools share the same position on the tool set. Click and hold the mouse on the visible tool to open the Pop-out tools list and select the desired tool.
To insert a tubular rivet:
1. Click the tool and mode.
2.Click to place the object, and click again to set the rotation. The first time you use the tool in a file, a properties dialog box opens. Set the default parameters. The parameters can be edited later from the Object Info palette.
Click
to show/hide the parameters.
