Angular dimensioning
Tool
Workspace: Tool set
Angular Dimension
●       Fundamentals, Architect: Dims/Notes
●       Landmark, Spotlight: Basic and Dims/Notes
The Angular Dimension tool measures and dimensions angles. Dimension the angle between two object edges, between two sides of a single object, between a single object and a reference line, or between two reference lines.
This tool works with all objects with linear or planar sides, including rounded and rotated rectangles, lines, polylines, polygons, and solids. It does not, however, work with circles, ovals, or arcs. In addition, it cannot dimension between parallel lines or lines on different planes.
If the Snap to Working Plane option on the Snapping palette is enabled, the face of the object being dimensioned must be parallel to the working plane.
Mode
Description
Edges
Dimensions the angle between two object edges or faces
Reference Line and Edge
Dimensions the angle between an object and a reference line
Reference Lines
Dimensions the angle between two reference lines
Dimension Standards
To change the dimension standard for new dimensions created in the document, select a standard from the list; select Custom Standards to create or manage custom dimensions (see Using custom dimension standards)
Angle between two object edges or faces
Angle between one reference line and an object
Angle between two reference lines
Editing dimensions
Associative dimensioning
