DesignSeries00011.pngManaging door hardware sets
Tool
Tool set
Shortcut
Door
Building Shell
●       Alt+Shift+D (Windows)
●       Option+Shift+D (Mac)
The Hardware pane of the Door Settings dialog box allows you to select items from the door hardware library to attach to door objects. The library includes information about each hardware set, which appears in the door hardware legend (see Creating door schedules). The library also includes a symbol to represent the hardware in 3D views of the door.
Use the Manage Hardware option in the Door Settings to customize the default content hardware library as needed, for yourself or for a workgroup.
To manage door hardware sets:
1.      Click the tool and then click Preferences.
Alternatively, select an existing door object, and click Settings in the Object Info palette.
The Door Settings dialog box opens.
2.On the Hardware pane, select Include hardware.
3.Click Manage Hardware.
The Door Hardware Library dialog box opens.
4.Click Add, or select a set and click Edit to open the Add or Edit Door Hardware Set dialog box.
A Description and Hdw Set ID are required for each set; other parameters are optional.
5.The edited library file is saved to your user folder. To use the library in a workgroup environment, move the file to a shared workgroup location; the folder structure must be the same as that of the default content library.
●       [User]\Libraries\Defaults\Door - Hardware\Door Hardware Library.txt
●       [Workgroup]\Libraries\Defaults\Door - Hardware\Door Hardware Library.txt
Sharing custom content using workgroup folders
Door settings: Hardware pane
