DesignSeries.pngInserting doors
Mode
Tool
Tool set
Shortcut
Door
Building Shell
●       Alt+Shift+D (Windows)
●       Option+Shift+D (Mac)
To insert a door:
1.      Click the tool and appropriate mode.
Alternatively, if placing a curtain wall door into a curtain wall, select a panel with the Edit Curtain Wall tool, and then right-click on the panel and select Insert Door from the context menu. The door is automatically inserted as a curtain wall door.
2.Do one of the following:
●       Click Active Def on the Tool bar to select a resource from the Resource Selector.
Individual manufacturer catalog items cannot be selected using the Resource Manager; see Concept: Plug-in object styles and catalog items.
●       Click Preferences to open the Door Preferences dialog box and specify the tool’s default parameters.
The parameters can be edited later from the Object Info palette. Additional parameters are available from the Object Info palette itself, as described in Door properties.
3.Click in the drawing area or in a wall to set the insertion point of the door, and click again to set the rotation. The direction of a door inserted in a wall can be changed later by clicking Flip from the Object Info palette or from the context menu.
Several features of the door are described as “interior” or “exterior.” These include trim and wall-wrap parts. These elements are determined based on the internal and external faces of the wall. The left side of the wall (as viewed along the wall direction) is always “exterior,” and the right side is “interior” (see Wall direction). Flipping the door does not flip these elements.
Door settings
Creating plug-in object styles allows you to create plug-in objects with a combination of parameters that are determined by the manufacturer’s catalog item, by style or by instance. Catalog parameters have a fixed value established by the manufacturer and cannot be edited by the user. Style parameters have a fixed value established by the style; instance parameters can be set independently for each instance of the object in the drawing (see Concept: Plug-in object styles).
Door settings: General pane
Door settings: 2D Visualization pane
Door settings: 3D Visualization pane
3D Visualization options are not enabled for the Opening Configuration.
Door settings: ID Tag pane
Door settings: Configuration: Barn Door pane
Barn Door options are enabled only for the Barn Configuration.
Door settings: Configuration: Pocket pane
Pocket door options are enabled only for the Pocket Configuration.
Door settings: Configuration: Sliding pane
Sliding door options are enabled only for the Sliding Configuration.
Door settings: Jamb pane
Jamb options are not enabled for the Opening Configuration or for curtain wall doors.
In Double Acting and Double Egress configurations, the leaves are mounted so that they are centered on the jamb when they are closed.
Door settings: Leaf pane
Leaf options are not enabled for the Opening Configuration.
Door settings: Second Leaf pane
Second door leaf options are enabled only for doors with a two-leaf Configuration and leaves of unequal widths; the narrower pane is considered the second leaf.
Door settings: Lights pane
Lights options are not enabled for the Opening Configuration or for curtain wall doors.
Door settings: Threshold pane
Threshold options are not enabled for the Opening Configuration.
Door settings: Louvers pane
Louvers can be applied to doors with all Configurations except Opening and Cased Opening.
Door settings: Transom pane
Transom options are not enabled for the Opening Configuration or for curtain wall doors.
Door settings: Trim pane
Trim options are not enabled for the Opening Configuration or for curtain wall doors.
Door settings: Lintel pane
Lintel options are not enabled for the Opening Configuration or for curtain wall doors.
Door settings: Hardware pane
Hardware options are not enabled for the Opening Configuration.
Door settings: Kick Plates pane
Kick Plates options are not enabled for the Opening Configuration or for curtain wall doors.
Door settings: Centerline Marker pane
Centerline markers options are not enabled for curtain wall doors.
Door settings: Interior Wall Detail pane
Interior wall detail options are not enabled for curtain wall doors.
Door settings: Exterior Wall Detail pane
Exterior wall detail options are not enabled for curtain wall doors.
Door settings: Classes pane
The visibility of the overall 3D door is controlled by the Class setting from the Object Info palette; part settings are controlled from the Door Settings dialog box.
Arch.pngDoor settings: Energos pane
Doors play a critical role in energy analysis calculations. Energy is lost through any door glass, and when the door is opened, but energy is also gained by solar radiation through the door glass. Accurately determining the R-Value/U-Value and the shading factor is essential for the overall energy analysis.
Vectorworks Architect is required to conduct an energy analysis; however, energy-related parameters can be specified here for informational purposes.
Door settings: Data pane
Certain data fields represent calculated values and cannot be edited; as a result, the Field Name and Field Value are grayed for those data fields.
List box functionality
Doors
Door properties
Creating door schedules
Energos energy analysis module
Door terminology specific to the United Kingdom
