List box functionality
Dialog boxes that contain long lists of information (such as the Organization dialog box) may have some or all of the following functionality.
Task
Action
Change the list’s sort key
Click the heading of the column to sort by; an arrow on the right side of the column heading indicates that it is the sort key
Reverse the sort order
Click the heading of the sort key column to toggle the sort between ascending and descending order
Change a row’s position in an ordered list
Click a row’s #/sorting column and drag to the desired position in the list
Resize a column
Click the vertical line on the right side of a column’s heading and drag it left or right
Edit a field with the mouse
●       Mac: Hover the cursor over an editable field to display an icon (either a pencil editing_icon.png, or a down arrow); click the icon to edit the field. If the editable field is within a selected row, click the field to edit it.
●       Windows: Click an editable field to display a blue outline around it; click again to edit the field.
Edit a field with the keyboard
Use the arrow keys to navigate around the editable fields in the list box. Press the F2 key (Windows) or Space Bar (Mac) to edit the highlighted field.
Select a group of rows
Click the first row, and then Shift-click the last row in the group
Select multiple rows individually
Click the first row, and then Command-click (Mac) or Ctrl-click (Windows) each additional row
Edit a row on the list
Double-click the row to open a dialog box for editing
Open a context menu for a row on the list
Right-click the row
For lists with a Visibility column, set the same visibility for all rows on the list
Option-click (Mac) or Alt-click (Windows) the desired setting
Display lists of classes in hierarchical order
To enable or disable hierarchical display of classes on pop-up menus in the Object Info palette, the View bar, and other dialog boxes, see Vectorworks preferences: Session pane.
To enable hierarchical display in the Classes tab of the Organization dialog box and the Navigation palette (Vectorworks Design Series required), see Displaying classes in hierarchical order.
Application window
