Editing plug-in object styles
Editing a plug-in object style changes every instance in the file that uses that style.
To edit a plug-in object style:
1.      Open the <Object> Style dialog box or Plug-in Object Style dialog box in one of these ways:
●       In the drawing area, right-click on a plug-in object that uses the style to edit, and select Edit Plug-in Style from the context menu.
●       From the Resource Manager, right-click on the style to edit, and select Edit from the context menu.
●       From the Object Info palette, select Edit Style from the Style list.
2.Set the parameters as described in Creating plug-in object styles.
Changing plug-in object styles from the Object Info palette
