Plug-in object styles applied to existing objects can be replaced or edited from the Object Info palette.
To replace the style of a selected object:
1. Select one or more objects.
2.From the Object Info palette, select Replace from the Style list.
The Choose a Plug-in Style dialog box opens.
3.Select the new style. The replacement style is applied to all selected objects.
To edit the style of all objects with the style:
1. Select an object.
2.From the Object Info palette, select Edit Style from the Style list.
The <Object> Style dialog box opens.
3.Edit the current style, as described in Creating plug-in object styles.
Editing a plug-in object style modifies all instances in the drawing that use that style.
To convert the instance to unstyled:
2.From the Object Info palette, select Convert to Unstyled from the Style list.
The object’s current values are retained, but all parameters are set to By Instance to allow editing.
