Spot00059.pngInserting pipe-and-drape assemblies
Mode
Tool
Workspace: Tool set
Modes for the Polyline tool
Soft Goods
●       Designer: Detailing
●       Spotlight: Event Design
The Soft Goods tool creates pipe-and-drape assemblies typically used in event planning, such as when creating temporary booths in a convention center. To draw a pipe-and-drape assembly, either use the Soft Goods tool, or create a polyline and then select the Create Objects from Shapes command (see Creating objects from shapes).
To display hanging points for soft goods objects, enable Hanging Point Classes in the Braceworks preferences (see Braceworks preferences).
1.      Click the tool and the creation mode.
2.Click Preferences to open the object properties dialog box.
3.Select Pipe-and-Drape from the Function list, and specify any other default parameters for this session. The parameters can be edited later from the Object Info palette.
4.Click to set the soft goods object’s start point.
5.Click to set the end of the segment and the beginning of the next. Continue drawing segments in this manner until the pipe-and-drape assembly is complete, and then double-click.
Once created, the soft goods object can be edited by selecting the object, and then selecting Modify > Edit Soft Goods. Reshape the soft goods polyline with the Reshape tool; click Exit Profile to return to the drawing.
To create an opening in the pipe-and-drape assembly, edit the vertex parameters from the Object Info palette. Select the vertex prior to the opening as described in Editing vertex-based objects, and then click Hide Next Edge.
Inserting curtains and borders
Setting soft goods 3D display options
Formatting soft goods object labels
Inserting soft goods
Concept: Attaching loads to rigging objects
