Spot00025.pngInserting a blended screen and projector
Tool
Tool set
Blended Screen
Event Design
The blended screen simulates projection screens that require multiple projectors to produce one large image.
Mode
Description
Modes for the Symbol Insertion tool
See The Symbol Insertion tool for parameter descriptions
Preferences
Sets the default properties for blended screen objects
Place Screen
Places and rotates the screen; the projectors can be added after placement
Place Screen and Projector
Places and rotates the screen and projectors
Screen Trim Height
Sets the Z value of the screen at insertion
To insert a blended screen and projectors:
1.      Click the tool and the symbol insertion and alignment modes.
2.Enter the Screen Trim Height value on the Tool bar.
3.Insert the object in the drawing.
●       In Place Screen mode, click to place the screen, and click again to set the rotation.
●       In Place Screen and Projector mode, click to place the screen, click again to set the screen rotation, and click again to place the projectors. This is especially useful when placing blended screens and projectors on rigging objects.
The first time you use the tool in a file, a properties dialog box opens. Set the default parameters. The parameters can be edited later from the Object Info palette.
4.When you use Place Screen mode to insert a blended screen, a Blended Screen object is created. Once the parameters of the blended screen and projectors have been set, click Insert Projectors from the Object Info palette to create the projectors associated with that screen. The blended screen settings control the initial projector settings, though each projector can then be set independently (by changing parameters like text position or cone display) if needed. Moving or rotating a blended screen after the projectors have been inserted also moves or rotates the associated projectors.
If projectors have already been inserted, clicking Insert Projectors deletes existing projectors and their parameter settings.
The height of the blended screen and associated projectors depends on several factors.
●       The Z value determines the distance from the active layer plane to the bottom of the screen (including the border).
●       When the screen includes legs, the legs are drawn on the active layer plane unless a Floor Height value has been specified. The Floor Height distance shifts the floor, and therefore the legs, by that amount from the layer plane.
●       Projector stands are inserted relative to both the Vertical Shift and Floor Height values, allowing stands to be shifted up or down from the screen’s floor as set by the Floor Height value.
●       In Top/Plan view, when one of the blended screen components, either the screen or the projectors, is placed on a rigging object, that component assumes the height of the rigging object and associates with it. In a 3D view, the height is determined by the component’s insertion point on the rigging object. The Manage Loads tool allows precise repositioning of the blended screen components; see Managing loads.
Blended screen parameters
Blended projector parameters
Setting the image on the video screen
Formatting video screen object labels
Concept: Attaching loads to rigging objects
