Mode |
Tool |
Tool set |
Modes for the Polyline tool |
Stage Plug
Event Design |
The Stage Plug tool inserts custom shaped stage structures into a drawing. The type, shape, size, and appearance can be customized.
To insert a stage plug:
1. Click the tool and the creation mode.
2.Click to set the stage’s start point.
3.Click to set the end of the segment and the beginning of the next. Continue drawing segments in this manner until the stage object is complete.
The first time you use the tool in a file, a properties dialog box opens. Set the default parameters. The parameters can be edited later from the Object Info palette.
The stage plug can be reshaped with the Reshape tool; see Reshaping objects.
Click
to show/hide the parameters.
