Spot00118.pngFind and modify
Command
Path
Shortcut
Find and Modify
Spotlight
●       Ctrl+Shift+Alt+M (Windows)
●       Cmd+Shift+Option+M (Mac)
Custom selection criteria can be defined to quickly and easily search for lighting devices, hanging positions, and accessories and to perform an action upon the search results.
To find and modify objects:
1.      Select the command.
The Find and Modify dialog box opens.
2.Select the type of object to search for and specify the changes to occur to the items found.
Inserting hanging positions
Adding lighting devices
Inserting and removing accessories in the drawing area
