Inserting and removing accessories in the drawing areaWithin the drawing area, the Lighting Accessory tool attaches and removes accessories from one lighting device at a time. Accessories are inserted in the default position.
To insert accessories in a custom position, or adjust the accessory position in 2D and 3D views, see Workflow: Editing accessories.
Mode |
Description |
Default Insertion |
Inserts an accessory in the default position |
Remove |
Removes an accessory |
Accessory symbol |
Opens a Resource Selector to select an accessory for placement; double-click a resource to activate it |
Mode |
Tool |
Tool set |
Default Insertion
Lighting Accessory
Lighting |
The Lighting Accessory tool inserts an accessory in the default position on the highlighted lighting device (or on the highlighted cell in a multi-cell device).
To insert an accessory in the default position:
1. Click the tool and mode.
2.Click Accessory symbol to select an accessory from the Resource Selector.
3.Click a lighting device to attach the accessory in the default position. Lighting devices are highlighted as the cursor moves over them. On a multi-cell lighting device, a diamond highlight indicates the cell where the accessory will attach. A preview shows where the accessory will be placed.
If an accessory symbol is accidentally inserted by the Symbol Insertion tool, the accessory functionality will not be present.
Mode |
Tool |
Tool set |
Remove
Lighting Accessory
Lighting |
The Lighting Accessory tool removes accessories from lighting devices in the drawing area.
To remove an accessory:
2.Hover the cursor over a lighting device with accessories; a diamond highlight indicates which accessory will be removed.
3.Click to remove the desired accessory.
