Spot00108.pngReplacing lighting devices
Command
Path
Shortcut
Replace Lighting Devices
Spotlight
●       Ctrl+Shift+Alt+R (Windows)
●       Cmd+Shift+Option+R (Mac)
Replacing a single lighting device
To replace an individual lighting device with another type of device:
1.      Select the existing device.
2.From the Object Info palette, click Replace Lighting Device.
3.From the Resource Selector, double-click the replacement device.
Replacing selected lighting devices
To replace selected lighting devices with another type of lighting device:
1.      Select the lighting devices to be replaced.
2.Select the command.
The Replace Lighting Devices dialog box opens.
3.Click Replace selected lighting devices.
4.Click the Resource Selector, and double-click a resource to select it.
Replacing all lighting devices of one type
To replace all lighting devices of one type:
1.      Select the command.
2.Click Replace All.
3.Click the Resource Selector, and double-click a resource to select it.
Editing lighting devices
Inserting lighting devices
