Editing lighting devicesOnce lighting devices have been inserted (normally, on a rigging object), many of the parameters of one or more selected devices can be changed from the Object Info palette and Lighting Device dialog box, and the color, numbering, alignment, and other options can be controlled.
Use the Rotate tool to rotate lighting devices interactively, about their individual insertion points. Only the standard 2D and 3D rotation modes are available for lighting device rotation. When a lighting device is rotated, all accessories attached to the device rotate with it. The relevant properties are automatically updated in the Object Info palette.
To select all lighting devices focused on a particular focus point, right-click on the focus point and select Select Focused Lighting Devices from the context menu. The focus point and any other selected objects are deselected automatically to facilitate faster editing of the lighting devices.
