Inserting
a photometer Mode |
Tool |
Tool set |
Modes for The Symbol Insertion tool |
Photometer
Lighting |
To insert a photometer:
1. Ensure that each lighting device contributing to the illumination is focused.
The light beams do not have to be drawn for calculations to be made.
2.Click the tool and modes.
3.Click to place the object in the drawing, and click again to set the rotation.
The first time you use the tool in a file, a properties dialog box opens. Set the default parameters. The parameters can be edited later from the Object Info palette.
Click
to show/hide the parameters.
After placing the photometer, set its Z value from the Object Info palette; illumination values vary depending on the photometer’s elevation.
