The Object Info palette: Render tab
Use this tab to assign and map textures to 3D objects.
If you selected multiple objects, select either Multiple Edit or Individual Edit mode, as described in Editing multiple objects. See Applying a texture to an object for details about how to use the Render tab.
Editing textures and shaders
Sketch rendering
Applying a sketch style to an object
