Land00042.pngCreating a plant line
Command
Workspace: Path
Plant Line
●       Designer: AEC > Plants
●       Landmark: Landmark
The Plant Line command creates a freehand plant line along a line, polyline, or polygon. It can be used to represent a single undefined plant, line of plants, or general plant mass. No specific plant symbol information is included in a plant line; use the Landscape Area tool if defined plant areas are necessary (see Creating landscape areas).
To create a plant line:
1.      Select the object (line, polyline, or polygon) with the Selection tool.
2.Select the command.
The Plant Line dialog box opens. Suggested values are based on the selection’s perimeter.
3.Select the desired plant line parameters. The plant line is created. If desired, apply colors, textures, and other attributes to the plant line with the Attributes palette.
The Attributes palette
