Command |
Path |
Show or Hide Plant Details |
View > Show |
The Show or Hide Plant Details command controls the visibility of the outline, massing, and shadow parameters set on the Visualization pane of a plant style (see Plant style: Visualization pane), on the Visualization pane of the plant preferences (see Advanced plant preferences: Visualization pane), as well as from the Object Info palette.
These effects display in Top/Plan view only. In a complex drawing with many plants, these settings can take a significant amount of time to display and edit, and it is useful to toggle the effects on and off.
To show or hide the plant details:
Select the command.
If the plant details are currently hidden, this command displays the outline, massing, and shadows of all plant objects with those parameters set. If the plant details are currently visible, this command hides the effects. The Outline selection is saved for the plants, even when hidden.
