Mode |
Tool |
Tool set |
Modes for Creating lines |
Break Line
Dims/Notes |
The Break Line tool creates one of three types of break lines: straight, curved, or arc.
On site models, pads with open edges, sometimes called break lines, can be created using the Site Modifier tool (Vectorworks Architect or Landmark required). See Creating a pad or pad with retaining edge.
To draw a break line:
1. Click the tool and mode.
2.Click to place the object in the drawing, and click again to set the rotation. The first time you use the tool in a file, a properties dialog box opens. Set the default parameters. The parameters can be edited from the Object Info palette.
Click
to show/hide the parameters.
