Creating double lines
Tool
Tool set
Shortcut
Double Line
Basic
●       Alt+2 (Windows)
●       Option+2 (Mac)
The Double Line tool creates a wide variety of constrained and unconstrained double lines. Set the width between the double lines, the offset from the cursor, and whether to create components between the double lines.
Mode
Description
Constrained
Constrains the line to be vertical, horizontal, and 30 degrees or 45 degrees from vertical or horizontal in any direction
Unconstrained
Draws the double lines at any angle.
Press and hold the Shift key to snap the line to predetermined angles.
Top Control Line
The cursor draws the top/left line
Center Control Line
Creates lines equidistant from the cursor
Bottom Control Line
The cursor draws the bottom/right line
Custom Control Line
Specify an offset value
Preferences
Opens the Double Line Preferences dialog box for specification of additional object parameters
Separation
The distance between the double lines; the value must be greater than zero
To create double lines:
1.      Click the tool and mode.
2.Click the desired offset mode to specify the offset method.
3.Enter the distance between the double lines in the Separation field on the Tool bar.
4.Click Preferences to set other parameters.
5.Click at the double line’s start point.
6.Click at the double line’s end point.
Applying components between double lines
Creating single lines
Creating a break line
Displaying and reversing object direction
Marker attributes
