Creating rounded rectangles
Rounded rectangles can be created with symmetrical, proportional, or unconstrained corner diameters.
Symmetrical corners have the same X and Y rounded corner diameters. Proportional corners are created as one third of the width and height of the rounded rectangle; for example, a rounded rectangle with a width of 6” and a height of 3” has a Diam X value of 2” and a Diam Y value of 1”. Rounded rectangles with both symmetrical and proportional corners have the same horizontal and vertical arc lengths. Unconstrained rounded rectangles can also be created using specific X and Y corner diameters.
Two modes are available. The Push/Pull mode is available in 3D views for instantly extruding the rectangle after creation.
Mode
Description
Diagonal
Defines the dimensions of the box containing the rounded rectangle
Rotated
Defines the width and height lengths to create the rounded rectangle, which can be rotated if desired
Push/Pull
(3D views only)
Instantly extrudes the rounded rectangle after creation; see Push/Pull mode of planar tools
Push/Pull Combine
(available with Push/Pull mode)
When the shape to be extruded is drawn on the face of a solid object, combines the two objects into a single solid addition or solid subtraction; when this submode is disabled, the new extrude remains a separate object, and the existing solid object remains unchanged
Preferences
Sets the default properties of rounded rectangles
Rounded rectangle by box
Mode
Tool
Tool set
Shortcut
Diagonal
Rounded Rectangle
Basic
●       Alt+4 (Windows)
●       Option+4 (Mac)
To create rounded rectangles by box:
1.      Click the tool and mode.
2.Click Preferences to open the Round Rect Preferences dialog box opens and specify the tool’s default parameters. The parameters can be edited later from the Object Info palette.
3.Click to set the start point.
4.Click to set the end point of the rectangle.
Rounded rectangle by width and height
Mode
Tool
Tool set
Shortcut
Rotated
Rounded Rectangle
Basic
●       Alt+4 (Windows)
●       Option+4 (Mac)
To create rounded rectangles by width and height:
2.Set the rounded rectangle preferences as described in Rounded rectangle by box.
4.Click to define the rounded rectangle rotation angle and width.
5.Click to define the rounded rectangle height.
Creating rectangles
