Extrude along path
Command
Path
Shortcut
Extrude Along Path
Model
●       Ctrl+Alt+X (Windows)
●       Cmd+Option+X (Mac)
The Extrude Along Path command extrudes profile objects along a given path. Profile objects can be 2D objects, 3D polygons, and NURBS curves. Profile objects cannot be non-planar, self-intersecting, or a mixture of 2D and 3D profiles. If the path is not a NURBS curve, it is converted into a NURBS curve during this operation.
When you use the Edit Extrude Along Path command on a 3D object created using the Extrude Along Path command, a dialog box opens with the choice to either edit the original path or profile object.
To extrude along a path:
1.      Select the object to be extruded, and the object to use as the path.
2.Select the command.
The Extrude Along Path dialog box opens. Specify the extrusion parameters.
Scaling options are available when the path object is a single continuous curve without sharp corners or discontinuities.
3.The type of Scale, Shape/Scale Factor, Lock Profile Plane, and Fix Profile status of an extrude along path object can be edited from the Object Info palette.
Single extrude
Multiple extrude
Creating a tapered extrude
Creating chain extrude objects
