ArchLand00075.pngCreating property lines
Use the Property Line tool to draw property lines. Alternatively, use one of the following methods.
●       Draw a polyline and then select the Create Objects from Shapes command (see Creating objects from shapes).
●       Draw arcs and lines, select Modify > Compose to create a single polyline, and then select the Create Objects from Shapes command.
Property Line tool
Tool
Tool set
Property Line
Site Planning
The Property Line tool interactively creates property boundaries from survey data. The resulting polyline is composed of line and/or arc segments. The closing segment can be automatically drawn and measured; each segment can be individually labeled with distance and bearing. Preformatted schedules provide information about property line segments and curves.
Mode
Description
Bearing and Distance
Draws a property line by sequentially specifying the bearing and distance of each linear or curved segment of the line
Polyline
Draws a property line using the selected polyline creation options and the current preference settings (see Property line parameters)
Polyline creation options
For Polyline mode, selects the method for drawing the polyline upon which the object is based; see Creating polylines
Preferences
Opens the object properties dialog box to set the default preferences for property lines
Creating property lines with bearing and distance data
Drawing property lines manually
