DesignSeries00089.pngEditing a railing or fence object
To edit the parameters for an existing railing or fence, select the object and click Settings from the Object Info palette. Alternatively, right-click the object and select Properties from the context menu. See Railing and fence settings.
To directly edit the object’s path or structural details, click the Reshape tool. The regular 2D reshape modes are available in Top/Plan view. Special modes are available if the object was drawn in 3D Line mode and you’re editing in a 3D view.
Frames and posts or brackets are automatically added or removed if you change the path length. To move control points precisely while editing, enter values in the Data bar.
The Reshape tool allows you to visualize railings and fences for your design, but the objects may not be suitable for production.
2D Reshape modes
Mode
Tool
Tool set
2D reshape modes
Reshape
Basic
To reshape the path of a railing or fence in Top/Plan view:
1.      In Top/Plan view, click the tool and mode. Alternatively, double-click the object, or right-click the object and select Edit from the context menu to activate the tool.
2.Drag the control points to reshape the object, or add or delete vertices.
If the object was drawn in 3D Line mode, you can use Move Polygon Handles mode to move the beginning and end points of the object; however, you cannot add, change, or delete vertices. Use the special 3D editing modes instead: Reshape 2D path mode, 3D Reshape base parameters mode, and 3D Reshape sub-objects mode.
Mode
Tool
Tool set
Reshape 2D Path
Reshape
Basic
To edit the path of a railing or fence drawn in 3D Line mode:
1.      In a 3D view, click the tool and mode. Alternatively, double-click the object, or right-click the object and select Edit from the context menu to activate the tool.
2.Drag the control points as follows:
●       Two end points: Change the object length
●       Middle point: Move the object without changing its length
Mode
Tool
Tool set
Reshape
Basic
To edit the height, length, or slope of a railing or fence drawn in 3D Line mode:
●       Middle point on top rail: Change the height
●       End points on top rail: Change the length
●       Points on bottom rail: Adjust the slope or orientation
Mode
Tool
Tool set
Reshape
Basic
To edit the sub-objects of a railing or fence drawn in 3D Line mode:
2.Drag the control points as follows.
●       Inside points on top rail: Change the height of the object
●       End points on top rail: Change the length of the rail extensions
●       Points on bottom of posts: Change the post position or length; press the Shift key while dragging to constrain the post movement along the same slope line, or to constrain the post length adjustment along the same vertical line
Creating railings and fences
Joining railings and fences
