ArchSpot00001.pngCreating structural members
The Structural Member tool has the capability to insert straight and polylinear structural members composed of a variety of common materials and shapes, and to build networks of associated members. If a material resource is used to define a part, the material typically provides the fill, texture, physical attributes, and construction information needed for drawings, renderings, and reports. Structural members can be aligned with the layer plane or a working plane, as needed.
Mode
Description
Column Insertion
Inserts a vertical member
Linear Insertion
Inserts a linear member
Poly Insertion
Draws a structural member using the selected polyline creation options
Polyline creation options
For Poly Insertion mode, selects the method for drawing the polyline upon which the object is based; see Creating polylines
Column Height
For columns with both the Start Bound and End Bound set to Layer Elevation in Structural member settings, enter the column height
Auto Join Members
When selected, automatically joins connected members and maintains the association between the member being moved and adjoining members; members can be joined to another member’s start or end point, centerline or edge. Associations are maintained for copied and duplicated objects, including objects moved to a different document.
Preferences
Opens the Structural Member Settings dialog box to set the default preferences for structural members
Creating vertical structural members
Mode
Tool
Workspace: Tool set
Column Insertion
Structural Member
●       Architect: Building Shell
●       Spotlight: Rigging
To create a vertical structural member:
1.Click the tool and mode.
2.Click Preferences to open the Structural Member Settings dialog box and specify the tool’s default parameters (see Structural member settings). Most of the parameters can be edited later from the Object Info palette.
3.Enter the Column Height on the Tool bar.
4.If Auto Join Members mode is enabled, as you move the cursor over an existing structural member, the object is highlighted, indicating that it can be associated. Click to place the structural member; it is inserted by its base.
Creating linear structural members
Mode
Tool
Workspace: Tool set
Linear Insertion
Structural Member
To create a linear structural member:
1.      Click the tool and mode.
3.If Auto Join Members mode is enabled, as you move the cursor over an existing structural member, the object is highlighted, indicating that it can be associated. Click to place the structural member’s start point, and click again to place the end point.
Creating polylinear structural members
Mode
Tool
Workspace: Tool set
Poly Insertion
Structural Member
To create a a structural member by drawing a polyline:
3.If Auto Join Members mode is enabled, as you move the cursor over an existing structural member, the object is highlighted, indicating that it can be associated. Click to set the starting point of the structural member, and then click to set each polyline vertex. Double-click to finish creating the structural member.
For information on using the polyline creation options, see Creating polylines.
Editing structural members
