For plug-in object styles and plug-in object instances (whether styled or unstyled), you can control some settings regardless of whether the plug-in object is, for example, a window or a title block border. Because these settings are inherent to plug-in objects and not to the object type, they are not accessed from the object properties dialog box.
To set the class or the 2D component and cut plane display settings for a plug-in object style or plug-in object instance:
1. Right-click on the resource in the Resource Manager or the instance in the drawing and select Plug-in Object Style Options or Plug-in Object Options from the context menu.
The Plug-in Object Style Options dialog box or Plug-in Object Options dialog box opens.
2.If you are setting options for the plug-in object style, set whether the parameters will be defined by style or by instance, and set the options (see Concept: Plug-in object styles). If you are setting options for an instance, verify the by style/instance settings to confirm that you can change the settings for this instance; however, the by style/instance setting can only be established from the Plug-in Object Style Options dialog box.
As with regular plug-in object parameters, when the options on these dialog boxes, including Class, are set by instance, they can be edited at any time. When set by style, any change to the plug-in object style’s settings changes all the objects in the file that use the style.
Click
to show/hide the parameters.
