Changing the class attributes of multiple symbol definitions
Command
Path
Change Symbol Attrs.
Tools > Utilities
This command assigns all of the contained objects within the symbol definitions from a selected location to the specified class, using any or all of the class attributes. This is a convenient way of changing the class attributes or appearance for several, or all, symbol definitions at one time.
Carefully evaluate the results of running this utility before making broad class changes to symbol definitions.
To change symbol definition class attributes:
Select the command. The Change Symbol Attributes dialog box opens.
Confirm the operation and the number of symbol definitions affected.
Editing symbol definitions
Applying object attributes
