Updating viewports
Changes that affect the appearance of a viewport are automatically updated for a wireframe viewport. However, if changes require the viewport to be rendered again, the viewport will be displayed as an out-of-date viewport.
If a sheet layer with an out-of-date viewport is printed, a message prompts you to either print the viewport as an out-of-date viewport or update the viewport on the sheet layer before printing.
Rendered viewport updates occur in the background for Renderworks render modes; you can continue working in the file while the viewports are updating. See Background rendering.
Updating selected viewports
Command
Path
Update Selected Viewports
●       View
●       Context menu
To update selected viewports:
1.      Select the viewports.
2.From the Object Info palette, click Update. Alternatively, select the command, or right-click on the viewport and select Update from the context menu.
Updating all viewports
Command
Path
Update All Viewports
View
To update all the viewports in the file:
Select the command.
All viewports on all sheet layers are updated.
Canceling viewport updates
Command
Path
Cancel All Viewport Updates
View
To cancel the updates of all viewports, including those queued to update for background rendering:
Select the command.
The updates are canceled.
Viewport status
Modifying viewports
Viewport properties
