DesignSeries00074.pngY wall joins
Mode
Tool
Workspace: Tool set
Shortcut
T Join
Wall Join
●       Architect and Spotlight: Building Shell
●       Landmark: Building Shell and Site Planning
●       Alt+J (Windows)
●       Option+J (Mac)
Y wall joins are not automatically created when you use the Auto-join walls preference. (See Vectorworks preferences: Edit pane for information on Auto-join walls.) Instead, use the T Join mode to create Y wall joins.
To create a Y wall join of three wall segments:
1.      Click the tool and mode.
Alternatively, right-click on the first wall to join and select Join from the context menu.
2.Select the wall segment that must change length to abut the two previously joined wall segments.
3.Select one of the two wall segments to join.
The wall segments are joined.
Joining walls
Joining walls with the Fillet tool
