Using saved sets
You can save the specified settings for reuse, and edit or delete saved sets.
Parameter |
Description |
Settings |
Displays the name of the current saved set; to use a different saved set, select it from the list of saved sets. Any set in the list with angle brackets indicates either a Vision default or a variable set, not a saved set. For example, <Active Settings> refers to the dialog box’s current parameters, which are not saved as a set. |
Save |
Opens the Save Settings dialog box to name and save the current parameter settings; the saved set is added to the Settings list |
Manage |
Opens the Manage Saved Sets dialog box, to rename or delete saved sets. Select a name from the list, and then click the appropriate button. When renaming a set, if the entered name is already assigned to another set, you are prompted to confirm that you want to replace the existing set. |
