Concept: Creating a connected rigging system
  Braceworks calculations and, in some cases, functionality depend upon creating connected rigging systems. As rigging objects are placed in the drawing, they can automatically connect to similar objects with the same cross section. Trusses, straight trusses, curved trusses, and lighting pipes and ladders can connect to form a system. Connected to those items, hoists and loads such as lighting devices and AV equipment are also considered part of the system, and they move or adjust with the system automatically. (See Concept: Attaching loads to rigging objects for a complete list of load objects.)
It is important to use the method of Changing the trim height of a system to adjust the height of structural systems and all connected objects properly. All of the items in the system move together, and the hoists’ chain lengths are automatically adjusted if needed.
When using the Truss tool, ensure that Auto Connect mode is enabled so that truss systems are automatically connected. Only compatible trusses can connect automatically. If the truss to connect does not cause an existing truss to highlight, it is because they are not compatible, or one of the rigging objects does not have a valid Connectable with parameter.
In Auto Connect mode, trusses can only connect to compatible connectors:
Spigot and connector plates can connect freely.
Gable can only connect to fork.
Spigot male can only connect to spigot female.
At insertion, Auto Connect mode automatically flips gable, fork, and spigot male/female trusses so they connect properly. An alert opens if a connection is not possible.
When adding other objects to the drawing, such as bridles, hoists, and loads, valid rigging objects are highlighted in red, indicating that if placed there, the new object will connect to the system. Copying and pasting rigging objects, and even entire systems, also uses auto connect functionality to connect to existing systems.
A completed truss system consists of truss lines connected with hinges or corner elements, as shown in these simple illustrations. Example naming of truss lines and the system are shown; see Renaming truss systems for more information.
The truss connection options are controlled by magnets within the truss symbol definition. Advanced users who create custom truss symbols can insert magnets automatically based on the truss record data or add them manually. See Concept: Truss magnets for more information.
