Spot04144.pngResetting Braceworks IDs
Command
Workspace: Path
Reset Braceworks IDs
Spotlight: Customize workspace to add command (see Customizing workspaces)
Braceworks: Braceworks
Braceworks requires unique IDs for its structural calculations. The Reset Braceworks IDs command ensures that the identifiers are unique, resetting them for all trusses, straight trusses, curved trusses, lighting pipe objects, and any objects with a weight or load (such as lighting devices, video screens, and so on). Any manually set IDs will be reset by this command.
To reset the ID of all Braceworks-related objects:
Select the command. The IDs are automatically reassigned.
Workflow: Working with Braceworks
Concept: Creating a connected rigging system
