Thumb screws
Mode
Tool
Tool set
Thumb Screw
Fasteners
The Thumb Screw tool and Thumb Screw - 3D tool share the same position on the tool set. Click and hold the mouse on the visible tool to open the Pop-out tools list and select the desired tool.
To insert a thumb screw:
Click the tool and mode.
Parameter
Description
Screw Type
Specify the thumb screw type
Point Type
Select the thumb screw point type
Size
Select the thumb screw size
Length
For a custom length value, deselect Use Standard Length Increments and enter the length under the screw head
Thread Style
(2D only)
Select the thread style; see Fastener object thread styles
View
(2D only)
Select the 2D view
Automatically adjusts the length to the nearest increment based on size, per ASME standards; deselect to enter a custom length
Show Center Line
(2D only)
Draws the thumb screw with center line(s)
Show Threads
(3D only)
Draws the 3D thumb screw with threads
Inserting fastener objects using the Fastener tool
Lag screws
Sheet metal screws
Wood screws
