Offset links
Mode
Tool
Tool set
Roller Chain - Offset Link
Machine Components
Multiple roller chain tools share the same position on the tool set. Click and hold the mouse on the visible tool to open the Pop-out tools list and select the desired tool.
The offset link connects a roller link and a pin link.
To insert an offset link:
Click the tool and mode.
Parameter
Description
Standard Chain No. (Pitch)
Select the standard ANSI or ISO roller chain number; the pitch is given as a reference
Show Pins
(3D only)
Displays the pins
Linear roller chains
Circular roller chains
