DesignSeries02716.pngManaging door hardware sets
Tool
Tool set
Shortcut
Door
Building Shell
Alt+Shift+D (Windows)
Option+Shift+D (Mac)
The Hardware pane of the Door Settings dialog box allows you to select items from the door hardware library to attach to door objects. The library includes information about each hardware set, which appears in the door hardware legend (see Creating door schedules). The library also includes a symbol to represent the hardware in 3D views of the door.
Use the Manage Hardware option in the Door Settings to customize the default content hardware library as needed, for yourself or for a workgroup.
To manage door hardware sets:
Click the tool and then click Preferences.
Alternatively, select an existing door object, and click Settings in the Object Info palette.
The Door Settings dialog box opens.
On the Hardware pane, select Include hardware.
Click Manage Hardware.
The Door Hardware Library dialog box opens.
Parameter
Description
Door hardware list
Lists descriptions of all defined hardware sets
Add
Creates a new hardware set
Remove
Removes the selected hardware set from the library. When prompted, confirm the deletion. Existing instances of the hardware set in the drawing are not modified.
Edit
Edits the selected hardware set
Click Add, or select a set and click Edit to open the Add or Edit Door Hardware Set dialog box.
A Description and Hdw Set ID are required for each set; other parameters are optional.
Parameter
Description
Description
Enter a description of the hardware set
Hdw Set ID
Enter a unique ID for the set
Hinge Qty
Enter the number of hinges
Hinge Type
Enter the hinge type
Lockset Type
Enter the lockset type
Closer Type
Enter the closer type
Stop Type
Enter the stop type
Key Code
Enter the key code
Notes
Enter notes about the door operator device
Symbol
Select a symbol from the default content to use in 3D views of the door
The edited library file is saved to your user folder. To use the library in a workgroup environment, move the file to a shared workgroup location; the folder structure must be the same as that of the default content library.
[User]\Libraries\Defaults\Door - Hardware\Door Hardware Library.txt
[Workgroup]\Libraries\Defaults\Door - Hardware\Door Hardware Library.txt
Sharing custom content using workgroup folders
Door settings: Hardware pane
