Formatting speaker object labels
  A variety of speaker and speaker array labels can be included in the drawing. Different options are available for speakers and speaker arrays. A speaker array, as well as the individual speakers that make up the array, can be labeled.
To select labels for display and format the text:
Select a speaker or speaker array object (bumper). From the Object Info palette, click Text Options.
The Text Options dialog box opens.
             Parameter  |
             Description  |
             Elements to Show  |
             Select items to add to the text label; different label elements are available for speakers and speaker arrays  |
             Round off dimensions  |
             Rounds dimensions to the nearest inch or millimeter  |
             Labels  |
             Includes the name of the element along with the value; deselect this option to display the parameter value only  |
             Text Attributes  |
             Keep text horizontal  |
             Maintains the text in a horizontal position even when the object is rotated; deselect this option to rotate the label along with the object  |
             Fill text background  |
             Allows a text background fill to be used for all speaker text; by default, white is used as the fill color. To specify a different fill color, click Classes in the Object Info palette, and then select a fill color for the class of the speaker text. The class should be set to Use at Creation.  |
             Text formatting options  |
             Specify the text size, color, and alignment  |
             Bubble and Leader Settings  |
             Specify the bubble type, leader type, and their attributes  |
Specify the text label elements and formatting.
Once the label has been added to the drawing, it can be moved by clicking and dragging the label control point. Click Default Text Position from the Object Info palette of a selected speaker or array object to restore the text label(s) to the original location.
