DesignSeries02291.pngEditing slab geometry with 2D modifiers
Adding a 2D shape to the slab surface
When adding to a slab, select whether the add operation should affect the entire slab or only certain components.
To add a 2D shape to a slab:
Create a closed 2D shape to represent the additional surface. The object must overlap the slab.
Select both the slab and the add surface object.
Select Modify > Add Surface.
The Add Shape to Slab dialog box opens.
Parameter
Description
Apply shape to entire slab
Adds the shape to the entire slab, affecting all components
Apply shape to selected components of slab
Select the components to be modified by the addition
Clipping a slab
When clipping, or subtracting from, a slab, select whether the clip operation should affect the entire slab or only certain components.
To clip a slab:
Create a closed 2D object to represent the clipping object. The object must overlap the slab.
Select both the slab and the clipping object.
Select Modify > Clip Surface.
The Clip Shape from Slab dialog box opens.
Parameter
Description
Clips the shape to the entire slab, affecting all components
Select the components to be modified by the clipping shape
Changing the slab modifier
Editing slab geometry with 3D modifiers
