DesignSeries02330.pngSlab drainage settings
Slab drainage settings for the selected slab are set before the drainage elements are added, in the Slab Drainage Settings dialog box; access it by clicking the Slab Drainage tool from the Building Shell tool set and then clicking Settings from the Tool bar. These settings serve as the new defaults for drainage elements added to the slab until the settings are changed.
Some, but not all, of the settings for individual drainage elements can be edited after placement with the Edit mode of the Slab Drainage tool (see Editing slab drainage elements).
Parameter
Description
Default Slope
Set the default slope for new slope valleys
Minimum Slope
Indicate the minimum slope; any slopes below this value are drawn differently to provide a visual indication
Drain Diameter
Set the default diameter for new drains
Drain Height
Set the default elevation relative to the top of the component for new drains
Maximum Height
Set the maximum height for any point on the curb
Elevation Offset
Set the elevation offset for new drains
Default drain symbol
Places a drain symbol at new drain locations; select the symbol
Drain Notes
To control appearance and visibility, select a class from the list of classes present in the drawing, or create a new class. Select <Slab Class> to place the drain notes in the same class as the slab object.
Elevations
To control appearance and visibility, select a class from the list of classes present in the drawing, or create a new class. Select <Slab Class> to place the elevation labels in the same class as the slab object.
Slope Arrows
To control appearance and visibility, select a class from the list of classes present in the drawing, or create a new class. Select <Slab Class> to place the slope arrows in the same class as the slab object.
Slope Values
To control appearance and visibility, select a class from the list of classes present in the drawing, or create a new class. Select <Slab Class> to place the slope values labels in the same class as the slab object.
Display Precision
Select up to ten digits of decimal precision for the slope values labels
Line Length
Enter the line length in world units of the lines for the slope arrows
Creating slab drainage systems
Correcting slab drainage errors
