Spot03763.pngPlacing lighting pipe ladders
Tool
Tool set
Lighting Pipe Ladder
Rigging
Insert and configure a lighting pipe ladder object with the Lighting Pipe Ladder tool. Lighting pipe ladders function as rigging objects, so lighting devices and other loads can attach directly to the ladder. Lighting pipe ladders support full 3D rotation, and they can be used to create schematic views.
In addition to individual objects created using the Lighting Pipe Ladder tool, you can access a variety of standard lighting pipe resources and custom styles (see Concept: Plug-in object styles).
Mode
Description
Point Insertion
Inserts the ladder vertically with two clicks to place and set the rotation
Rectangle Insertion
Inserts the ladder horizontally by clicking two diagonal points
Width
Sets the ladder’s width, for use with Point Insertion mode
Height
Sets the ladder’s height, for use with Point Insertion mode
Preferences
Opens the object properties dialog box to set the default preferences for lighting pipe ladders
Style
Opens the Resource Selector to select a symbol for placement; double-click a resource to activate it
To insert a lighting pipe ladder:
Click the tool.
Do one of the following:
Click Style on the Tool bar to select a resource from the Resource Selector.
Click Preferences to open the object properties dialog box and specify the tool’s default parameters.
The parameters can be edited later from the Object Info palette.
To insert a vertical ladder, click Point Insertion mode and set the ladder’s Width and Height.
To insert a horizontal ladder, click Rectangle Insertion mode.
Click twice in the drawing area to draw the lighting pipe ladder according to the modes selected.
Optionally, create a style resource from the object (see Creating plug-in object styles).
Parameter
Description
Roll
Rotates the lighting pipe ladder on its X axis; the pipe rotates around its insertion point
Hanging Angle
Rotates the lighting pipe ladder on its Y axis; the pipe rotates around its insertion point.
When this angle is adjusted, attached load objects may appear to overlap in Top/Plan view.
Rotation
Rotates the lighting pipe ladder on its Z axis; the pipe rotates around its insertion point
Style
Replace, remove, or edit the current style, or create a new plug-in object style for this object.
Editing a style changes all instances in the file that use the style.
Hide Style Parameters
Hides the parameters that are set by style; these cannot be edited from the dialog box or Object Info palette
General
Ladder Width/ Height
Specifies the lighting pipe ladder dimensions
Guides
Select how to draw the ladder based on the preview guide rectangle: on the ladder center, inside, or outside
Number of Rungs
Specifies the number of ladder rungs
Evenly Spaced Rungs
Spaces the rungs evenly within the ladder frame; deselect to specify custom rung spacing
Custom Rung Spacing
Opens the Custom Rung Spacing dialog box, to specify the spacing between each ladder rung.
Enter the distance between the rungs; the distance from top updates automatically. Click Calculate Even Spacing to automatically space the rungs evenly, as a starting point for spacing or to reset the values; the first and final distances are automatically calculated. To set the top rung to the position at the top of the ladder, click Set Top to Top. To set the bottom rung to the position at the bottom of the ladder, click Set Bottom to Bottom. The position of the other rungs does not change.
Position Name
Enter a name for identification and reporting purposes. When the lighting pipe ladder is used as a hanging position, this name automatically populates the Position field of any attached load objects.
Index
Specifies a unique identifier for the ladder, which is combined with the Position Name for identification and reporting
Location
Optionally, specifies the location for use in reports
Weight
Displays the total weight of the lighting pipe ladder
Pipe
Draw Pipe
Shows or hides the 2D component of the lighting pipe ladder
Line Type
Select either a single or double line for Top/Plan views
Curved Top
Creates a ladder with a curved top
Measure first rung from
Select whether to measure the first rung from the top or the arc or base of the arc
Show Snap Guide
Displays a snap guide
Rungs
Diameter
Sets the rung diameter
Render Profile
Select the 3D profile of the rung; this setting affects rendering speed (shapes other than round may render more quickly)
Sides
Verticals
Select where to draw the vertical supports
Profile
Select the side profile
Diameter
Sets the pipe diameter for the sides
Depth
For rectangular profiles, set the depth
Construction Material
Select the material (aluminum, steel, and so on) of the lighting pipe ladder
Wall Thickness
Specifies the thickness of the pipe wall
Tick Mark
Display ticks as
Choose how to display evenly-spaced marks to assist with lighting device placement; all options except None also provide master snap points along the lighting pipe ladder when hovering over it.
Centers
Specifies the distance between tick mark centers
Snap intervals between ticks
Specifies the distance between master snap points
Origin
Starts the tick mark placement at the center of one side of the ladder or split equally from the center of one of the ladder sides
Type
Select Line or Dot as the 2D tick mark indicator
Size
Specifies the length of line tick marks or the diameter of dot tick marks
Gap Length
Adds a gap on either side of the tick mark; specify the gap length
Offset
Specify a positive or negative value to shift the tick marks right or left from their centers
Align Tick Marks to Grid
Aligns the center tick mark with the snap grid (see Snapping to the grid); this does not change the tick mark spacing but it may change the Offset value
Classes
Use Standard Classes
Opens the Use Standard Classes dialog box to set the class prefix used by the pop-up class settings below.
Select Existing class to use an existing class from the document as a prefix. Select Other prefix to create a new custom prefix without creating the class.
List of lighting pipe ladder parts
To control appearance and visibility, select a class from the list of classes present in the drawing, or create a new class. Select <Lighting Pipe Ladder Class> to place the part attributes in the same class as the lighting pipe ladder object.
Settings
Opens the Lighting Ladder Settings dialog box, to set the default class for the lighting pipe ladder.
Select the Make default for new documents option to always use the specified class as the default class for lighting pipe ladder objects in new files.
Inserting hanging positions
Concept: Hanging positions
Concept: Rigging objects
