Snapping to the grid
Tool
Location
Snap to Grid
Status bar
The snap and reference grids assist with precise drawing on both design and sheet layers, as described in Snap and reference grids.
When snap to grid is on, the SmartCursor snaps to set points on the snap grid. For example, if the grid is set to 1”, as the cursor moves over the grid, it automatically “catches” every inch. When you create a line (if no other snapping is active) the line’s first and last point will lie on the snap grid. Snap to grid is the only type of snapping that does not provide any sort of visual cues. If snap to grid is on, the cursor is always on the grid, unless other snaps are also selected which override snap to grid.
When snap to grid is on, the working plane displays with “dots.” The dots do not display for working planes when snap to grid is off. See Appearance of the planes.
To activate snapping to the snap grid:
Click the tool.
To change settings, if needed, double-click, right-click, or click and hold the tool to open the Grid Settings popover and set the parameters.
Grid snap settings can also be set as part of the document setup; see Document setup.
Parameter
Description
Snap Grid
The grid that aligns (snaps) objects during drawing and editing, when Snap to Grid is active
Symmetrical
Constrains the Y setting to be the same as the X setting, resulting in a symmetrical grid
X and Y
Sets the grid dimensions in the X and Y directions; the Y setting is grayed if Symmetrical is selected
Reference Grid
The visible grid used for visually aligning objects during drawing and editing
Symmetrical
X and Y
Sets the grid dimensions in the X and Y direction; the Y setting is grayed if Symmetrical is selected
Grid Options
Sets how the reference grid behaves on screen and when printing
Show grid
Displays the reference grid when possible (even with this option selected, the reference grid may not display depending on the zoom factor); also displays the active layer plane grid in 3D views.
Print grid
Prints the reference grid on both design layers and sheet layers
Show 3D axes
Shows the X, Y, and Z grid axes in 3D views (the Z axis can be independently displayed or hidden)
Show 3D Z axis
Shows the Z axis in 3D views and for working planes
Show 3D axis labels
Shows labels for each axis in the active layer plane and working plane
Reset to Defaults
Resets the grid snap settings to the defaults
SmartCursor cues
Setting snapping parameters
Drawing with snapping
