Arch02905.pngChanging the panel schedule format
Command
Path
Create Panel Schedule
Tools > Reports
To format a panel schedule:
Select the command.
The Create Panel Schedule dialog box opens.
Select the panel schedule and its location.
Click Edit.
The Schedule Formatting dialog box opens. Select the schedule to format from the Schedule list. A list of available fields and, if applicable, the schedule’s printed name displays.
Parameter
Description
Schedule
Printed Name
Specifies the name that is printed on the schedule
Available Fields
Lists all possible schedule column items
Schedule Columns
Lists, in order, all included schedule columns
Move >
Moves a selected item from the Available Fields list to the Schedule Columns list
< Move
Moves a selected item from the Schedule Columns list back to the Available Fields list
Move Up/Move Down
Moves a selected item in the Schedule Columns list to adjust the list order
Printed Schedule Width
Specifies the total width of all schedule columns when printed
Column Headers
Displays the current font, style, and size for header information in the schedule. Click Change to edit the font format.
Body
Displays the current font, style, and size for body text in the schedule. Click Change to edit the font format.
The columns shown in the Column Order list appear in the schedule in order.
Panel schedule formatting is stored as a worksheet named “Panel Schedule Fmt.” This worksheet can be imported, using the Resource Manager, into other files where the same formatting is desired.
Click OK to return to the Create Panel Schedule dialog box. Click OK to place the schedule with the specified format.
Creating a panel schedule
Creating panel riser diagrams
