Arch02904.pngPanel scheduling and diagramming
Creating a panel schedule
Command
Path
Create Panel Schedule
Tools > Reports
The Create Panel Schedule command generates panel schedules based on the circuiting information assigned to the file. If necessary, modify the dimensions and layout of the panel to conform to existing office standards.
To create a panel schedule:
Select the command.
The Create Panel Schedule dialog box opens. Specify the panel schedule criteria.
Parameter
Description
Panel list
Select a panel from the list of available panels for creating the schedule
Place in worksheet
Places scheduling information in a worksheet resource named with the panel name
Place in Document
Places a panel schedule on the drawing
Choose Schedule
Indicates the location for placing the panel schedule on the drawing
Layer
Specifies the layer for placing the schedule
Class
Specifies the class for the schedule
Panel Style
Select the panel formatting style from the list
Edit
Changes the panel schedule formatting
If you selected the option to place the schedule on the drawing, click at the desired location.
If you selected the option to place the panel schedule in a worksheet, a worksheet is created with the panel name.
If circuiting changes are made, delete the outdated panel schedule and repeat the create panel schedule procedure.
Changing the panel schedule format
Creating panel riser diagrams
