Land03400.pngCreating existing trees from loci
Command
Workspace: Path
Create Existing Trees from Loci
Design Suite: AEC > Existing Trees
Landmark: Landmark > Existing Trees
Loci with tree survey data, which may have come from a survey file, imported DXF/DWG file, or point-based shapefile, can be converted to existing tree objects with the proper attached information, including location. By mapping the attached data to the existing tree record fields, valid existing tree objects are created in the Vectorworks Landmark file.
To create existing trees from loci:
Select the loci, or select symbols that contain the loci.
Select the command.
The Create Existing Trees from Loci dialog box opens.
Parameter
Description
Saved Settings Options
See Using saved sets to save and apply saved settings
Survey Data
Use Attached Record
Select a record attached to the loci to map to existing tree parameters; when deselected, the existing tree objects are created with the default values of the Existing Tree tool, and no mapping is possible
Preserve Record in new Existing Trees
Attaches the selected record to the created existing tree objects, so that all record data is preserved
Record Mapping table
Each row in the table corresponds to a row in the selected record
Field Name
Lists the record field names
Parameter
For each row, indicates the existing tree parameter that the Field Name item is mapped to
Unit
For each row, indicates the unit that will be used during mapping.
If the imported row contains text or entries which do not need a unit, leave the default selection of None/Automatic.
If data can be mapped with the specified document units, this will occur automatically with the selection of None/Automatic.
If the imported data requires units that are different from the document defaults, select the unit to use for importing the data.
Field Type
Displays the type of record field, for informational purposes
Selected Existing Tree Parameter
Indicates how the selected row data should be mapped to its equivalent parameter at import
Selected Unit
Indicates the units for the selected row at import
If using a record attached to loci as the basis of the existing tree parameters, select the record, and then select each row of the record mapping table. Specify how each row should be mapped to the equivalent existing tree parameter by selecting it from the Selected Existing Tree Parameter. If necessary, select the specific units that should be used if they are different from the document defaults.
When mapping to existing tree parameters, the associated data values are mapped directly when the type is compatible. For example, when the height parameters are mapped, the height value from the record becomes the Height value for the existing tree; a mapped Condition parameter is set as expected if the entry matches one of the default options (Excellent, Good, Average, Poor), or to Custom if the entry does not match the defaults.
If no data are provided for mapped parameters, the default values of the Existing Tree tool are used.
Save the mapping settings if needed.
Click OK to create the existing tree objects from the loci.
Importing existing trees from a survey file
Placing existing trees
Workflow: Existing tree placement
