Applying components between double lines
To apply a component between the double lines:
In the Double Line Preferences dialog box, click Components. The Double Line Components dialog box opens. Specify the component details.
Defining double line components
To define a double line component:
In the Double Line Components dialog box, click New, or select a component and click Edit. The Double Line Component Settings dialog box opens. Specify the component details.
Click to show/hide parameters.Click to show/hide parameters.
Parameter |
Description |
Definition |
Class |
To control appearance and visibility, select a class from the list of classes present in the drawing, or create a new class. Select <Object Class> to place the component attributes in the same class as the double line object. |
Thickness |
Specify the component’s thickness. A component must have a thickness greater than 0. |
Fill |
Select a fill style or Class Style to set the fill attributes by class. Depending on the Style selected, select a color, pattern, or resource (hatch, tile, gradient, image). Component fills are visible only for double lines created with Create Polygons or Create Lines and Polygons selected in the Double Line Preferences dialog box; see Creating double lines. |
Left/Right Pen |
Select a pen style or Class Style to set pen attributes by class. Depending on the Style selected, select a color, pattern, or line type resource. |
Thickness |
Select the line thickness. To use a custom thickness, select Set Thickness from the line thickness list (see Line thickness attributes). |
Make All Attributes By Class |
Sets fill and pen attributes by class |
Remove By Class Settings |
Removes all class settings for fill and pen attributes |
