Editing elevation
Mode |
Tool |
Workspace: Tool set |
Edit Elevation
Grade |
Architect and Spotlight: Building Shell Landmark: Site Planning |
If the elevation changes after one or more grade objects have been placed, there is no need to replace the existing grade objects. Change the elevation of one end of a grade object, or offset the elevation of selected (or all) grade objects in the drawing.
Elevation marker symbols must be at a valid scale to edit elevations. If the Edit Elevation dialog box does not open, increase the marker scale factor for the grade object.
To edit grade object elevation:
Click the tool and mode.
Click at the start or end of a grade object.
On the Edit Elevation dialog box, edit the grade.
Parameter |
Description |
Elevation at Selected End Marker |
Changes the elevation for the selected end of the grade object |
Offset Selected Grade Objects |
Adjusts the elevation of all selected grade objects by the specified amount |
Offset All Grade Objects |
Adjusts the elevation of all grade objects in the file by the specified amount |
