Joining railings and fences
Tool |
Workspace: Tool set |
Railing/Fence Join
Architect: Furn/Fixtures Landmark: Site Planning and Furn/Fixtures Spotlight and Braceworks: Event Design |
The Railing/Fence Join tool connects horizontal and sloping railings or fences.
This tool allows you to visualize railings and fences for your design, but the objects may not be suitable for production.
Mode |
Description |
Single Railing/Fence Connect
Trims or extends the first selected object to join a second object |
Dual Railing/Fence Connect
Trims or extends to join two objects at their endpoints or intersections |
Dual Railing/Fence Combine
Trims or extends to join two objects into one object at their endpoints or intersections. Sloping objects cannot be combined. |
Miter Connect
For Dual Railing/Fence Connect mode, miters the objects at the join |
Blunt Connect
For Dual Railing/Fence Connect mode, cuts the object ends vertically at the join |
Blunt Connect on Both Sides
For Dual Railing/Fence Connect mode, cuts the object ends vertically at the join; both objects are extended or trimmed to the closest intersection point |
Fix Sloping Angle
For a sloping object, connects without changing the slope; when disabled, the slope may change to make the tops of the objects flush |
Fix Top Rail Height
Connects without changing the top rail height; when disabled, the rail height may change to make the tops of the objects flush |
Single railing/fence connect
Mode |
Tool |
Railing/Fence Join |
Architect: Furn/Fixtures Landmark: Site Planning and Furn/Fixtures Spotlight: Customize workspace to add tool (see Customizing workspaces) |
To connect a single horizontal or sloping railing or fence to another one:
Click the tool and mode.
Set the Fix Sloping Angle and Fix Top Rail Height modes as desired to either keep the slope angle and top rail height fixed, or to allow the first object to be modified when connected to the second object.
Click the object to connect, and then click the object to connect it to. The first object is trimmed or extended to join the other object.
Dual railing/fence connect
Mode |
Tool |
Railing/Fence Join
To connect two horizontal or sloping railings or fences:
Set the desired mode for the angles of the connected ends:
Miter Connect: Both ends mitered at the join
Blunt Connect: Both ends cut square at the join
Blunt Connect on Both Sides: Both ends cut square, and joined at the closest intersection point
Click the object to connect, and then click the object to connect it to. Both objects are extended or trimmed to join each other.
Dual railing/fence combine
Mode |
Tool |
Railing/Fence Join
To combine two horizontal railings or fences into a single object:
Select the Fix Top Rail Height mode to keep the top rail height fixed, or deselect it to allow the first object to be modified when the objects are combined.
Click the first, and then the second, object to combine. The two objects are trimmed or extended and combined into one object.
If one or both objects are sloping, a message displays that they cannot be combined. Instead, they’re connected as in Dual Railing/Fence Connect mode with a miter join.
