Batt insulation
Mode |
Tool |
Tool set |
Modes for Creating lines |
Batt Insulation
Detailing |
The Batt Insulation tool draws a planar insulation fill along a line. This tool is useful for creating custom details. The insulation can be placed within a wall, where it automatically adjusts to the length of the wall.
A better method of creating insulation fills, especially for walls, is to use a tile fill, which scales and rotates within walls and slab and wall components.
To create batt insulation:
Click the tool and mode.
Click to place the object in the drawing, and click again to set the length and rotation. The first time you use the tool in a file, a properties dialog box opens. Set the default parameters. The parameters can be edited later from the Object Info palette.
The created batt insulation can be dragged into an existing wall.
Parameter |
Description |
Insert |
When inserted in walls, aligns the insertion point of the batt insulation with the containing wall’s center line or left or right edge |
Break |
When inserted in walls, select the type of wall break for the batt insulation |
Height |
When inserted in walls, sets the height of the insulation from the bottom of the wall |
Flip |
When inserted in walls, flips the orientation of the batt insulation |
Set Position |
When inserted in walls and with Size to Wall Length selected, sets the insulation to fit along the length of the wall. The Move By Points tool is activated automatically; if Size to Wall Length is deselected, set the offset of the batt insulation along the wall as described in Moving symbols in walls with the Move by Points tool. |
Length |
Specifies the length of the batt insulation, when Size to Wall Length is deselected |
Thickness |
Sets the width of the batt insulation |
Offset |
Sets the offset of the batt insulation from its insertion point |
Folds/Unit Thk. |
Sets the thickness of the insulation folds |
Size to Wall Length |
When inserted in walls, automatically sets the length of the batt insulation to match the wall length |
Add to Start/End |
Specifies an offset from the start or end of the wall, when the batt insulation is sized to fit the wall length |
