Applying wall styles
By a variety of methods, wall styles can be selected for a wall before drawing it, or applied to existing walls. Once a wall style has been selected for a wall, the Attributes palette is no longer available for changing wall attributes; attributes are set as part of the style.
To apply a wall style prior to drawing a wall:
Click the Wall or Round Wall tool.
Click Wall Style on the Tool bar to select a resource from the Resource Selector.
Alternatively, click Preferences to open the Wall Preferences dialog box, and select the Wall Style.
To apply a wall style from the Resource Manager prior to drawing the wall:
Ensure that no walls are selected.
From the Resource Manager, right-click on the resource, and select Apply from the context menu. Alternatively, double-click on the resource to activate it.
The Wall tool is automatically selected and the selected wall style is applied to the wall as it is drawn. (If a round wall is desired, select the Round Wall tool from the Building Shell tool set.)
To apply a wall style to an existing wall from the Object Info palette:
Select one or more walls.
From the Object Info palette, select Replace from the wall Style list and see the instructions in Replacing wall styles from the Object Info Palette.
To apply a wall style to an existing wall from the Resource Manager:
From the Resource Manager, right-click on the resource, and select Apply from the context menu. Alternatively, double-click on the resource or drag the resource onto an object to apply it.
The Wall Replacement dialog box opens.
Select the wall alignment properties. The wall style selector is disabled (the style selected in the Resource Manager is applied).
A styled wall can be converted to an unstyled wall.
To remove a wall style:
Select one or more walls to un-style.
From the Object Info palette, select Convert to Unstyled Wall from the wall Style list.
The wall is released from its style; its attributes can be edited from the Attributes palette.
