DesignSeries02377.pngHiding wall components
Command
Path
Document Preferences
File > Document Settings
The Auto-display detail levels for design layers preference prevents wall components from being drawn at or below a pre-set layer scale factor, creating a cleaner drawing at small scales.
To hide wall components:
Select the command.
The Document Preferences dialog box opens.
On the Display tab, select Auto-display detail levels for design layers. Enter the scale factors in the scale fields. Wall components display automatically at medium and high detail levels, and do not display at the low setting. See Document preferences: Display tab.
Joining wall components
Creating wall end caps
Creating walls
