General snapping settings
Tool
Location
Snapping Settings
Status bar
The general snapping parameters specify global SmartCursor functionality.
To set general snapping parameters:
Click the button to open the General Snapping Settings popover and set the parameters.
Parameter
Description
Show SmartCursor cues
Displays SmartCursor cues while drawing. The cues displayed depend on the combination of snapping tools enabled, as well as the current cursor position.
Show snap points
Displays temporary graphical hints to indicate that a snap point is available; see Concept: Snapping indicators for more information. Deselect to hide snap points.
Zoom line thicknesses in Snap Loupe
When using the snap loupe (see Using the snap loupe), sets the line thicknesses relative to the zoom level so that objects display normally in the loupe view
Snap to combined page area
Snaps to the edges and center of the combined printable area of design layer and sheet layer pages
Snap to individual pages
Snaps to the edges and center of the individual pages within design layer and sheet layer pages
Ignore non-planar snaps in planar contexts
Snaps only to snap points that are planar within the current plane’s context, ignoring snap points that are not co-planar. When using the automatic working plane with a tool that operates on a plane, the current planar context is the plane that is acquired by the automatic working plane. When not using the automatic working plane, and you are creating a 2D object, the current planar context is the current working plane.
This is useful in Wireframe mode when the automatic working plane is on, and the cursor is over a planar face (not a curved face); and when the automatic working plane is off, and you are drawing planar objects. It is not needed in rendered views because snapping does not occur for geometry hidden behind solid objects.
Interactive Appearance Settings
Opens a dialog box to change the appearance of the interactive elements in the Vectorworks program, including general elements, object highlighting, SmartCursor elements, and snap points; see Configuring interactive display
Reset All Snaps to Defaults
Restores default parameter settings for all snapping types
SmartCursor cues
Setting snapping parameters
Drawing with snapping
Using working planes
